X64 cross compiling - How to get it going guide.
Postby AndyC » Tue Aug 12, 2014 2:20 pm
AndyC
Re: X64 cross compiling - How to get it going guide.
Postby maynarde » Sat Aug 16, 2014 3:01 am
**** This post is irrelevant as of 8/16/2014
FWIM - Lubuntu 14.04.01 x64: So I was following this guide and things were going well until I encountered an error running the toolchain build script for the x64 linux host. The script would abort because it claimed that it could not find a c++ compiler. Looking back at the instructions, I replaced the step about installing arm-linux-gnueabihf with:
$sudo apt-get install git build-essential gcc-arm-linux-gnueabi libncurses5-dev u-boot-tools qemu-user-static debootstrap binfmt-support libusb-dev pkg-config gcc-arm-linux-gnueabihf
Not sure why I did not have the correct c++ compiler but it ended up downloading a LOT of files. Looks like the build went through without the error after doing this. If I had to guess (what follows is uninformed speculation) it is the pkg-config that was the win. I also has to uncomment the download commands in the script to make progress (I think - the above was after the uncomment)
I will post an update when I can get a "hello world" cross compile to execute.
maynarde
Postby maynarde » Sat Aug 16, 2014 3:13 am
Nope. Build bailed with:
/home/emaynard/epiphany-sdk/srcw/gcc/gengtype-state.c:27:21: fatal error: bconfig.h: No such file or directory
#include "bconfig.h"
compilation terminated.
make[1]: *** [gengtype-state.o] Error 1
rm fsf-funding.pod gcc.pod
make[1]: Leaving directory `/home/emaynard/epiphany-sdk/bld-epiphany/gcc'
make: *** [all-gcc] Error 2
it's late and I will pick this up tomorrow.
maynarde
Postby AndyC » Sat Aug 16, 2014 5:30 am
Hi Guys,
It looks like they have changed the toolchain and esdk stuff in the last couple of days, when did you download it?
Cheers
Andy
AndyC
Postby aolofsson » Sat Aug 16, 2014 2:06 pm
SDK undergoing massive overhaul at the moment. Unfortunately this means the main branch is unstable right now. Everything will be up and running by end of august. Until then, cross compiling from x86 will not be available. Tar balls for parallella native tool chains available.
Postby maynarde » Sat Aug 16, 2014 3:57 pm
Thanks for the replies. I will check back next month. Cheers!
maynarde
Postby a.nonyme » Tue Aug 19, 2014 8:50 am
a.nonyme
