ALSA - SND_PCM_STREAM_PLAYBACK issues
Postby AndyC » Thu Aug 14, 2014 9:57 am
Hi Guys,
I know a couple of you have been using alsa so maybe you could help me with this.
I have a iconnectmidi4 interface attached via usb, audio playback and capture work fine as long as you don't try to do both together!
If a SND_PCM_STREAM_CAPTURE stream is created the playback stream stops producing audio, when the SND_PCM_STREAM_CAPTURE is closed the playback magically starts again.
I have tested this interface on another linux box and it doesn't act like this, it works properly.
Anyone any ideas?
Cheers
Andy
AndyC
Re: ALSA - SND_PCM_STREAM_PLAYBACK issues
Postby AndyC » Thu Aug 14, 2014 10:38 am
Ok, just tried it with another usb interface (Roland DUO-Capture EX) with exactly the same problem.
AndyC
Postby AndyC » Thu Aug 14, 2014 12:41 pm
I just connected up a USB hub so I could connect the DUO-Capture and iConnectMIDI4 at the same time to test capture from on and playback on the other, this worked.
Then I tested capture and playback with the iConnectMIDI4 and it worked!
So I disconnected the DUO-Capture to see if that affected it and it didn't.
So using a USB hub has magically fixed the issue!
Very strange!
AndyC
