accessing to the share and local memory
Postby aihaike » Fri Aug 15, 2014 5:32 am
Dear all,
I got pretty much confused about how the host and the core access to the share memory.
From my understanding e_read is used by the host end cores to access to the local memory of a given core, is that correct?
In my code I need the host to read and write to the share memory and each core.
I also wonder if the 1G SDRAM actually correspond the share memory.
Finally, I did not see example using array. Is it possible transfer arrays from CPU to share and local memories of the coprocessor?
Thank you.
Éric.
aihaike
Re: accessing to the share and local memory
Postby greytery » Sat Aug 16, 2014 8:33 am
Postby aihaike » Sun Aug 17, 2014 11:03 pm
Thank you Tery, it's clear now.
aihaike
