No Penguins?
No Penguins?
Postby JohnR » Fri Aug 15, 2014 6:51 pm
I now have my Parallella set up with a keyboard and mouse connected via an unpowered hub and both seem to work.
The serial output is connected via a MM232R serial-USB converter and accessed using TeraTerm which seems to work fine.
Ethernet is not connected yet.
The board is powered by a lab power supply and at 5.0V draws 1100mA.
The monitor is a Bravia display running in HDMI mode.
At bootup the Parallela logo is displayed but the screen resolution seems wrong as all I see is the logo and
there is no sign of a Linux desktop. Nor do I see at any stage the Linux penguins.
What should I be seeing at this stage?
The demo 'screensavers'( the fireworks(?) and falling shapes(?) displays ) seem to overfill the screen.
How do set the screen resolution?
Thanks for any help
JohnR
Re: No Penguins?
Postby cmcconnell » Fri Aug 15, 2014 8:25 pm
Is your monitor a TV display, defaulting to overscan mode?
I was initially caught out by that with my LG TV/monitor. Switching the aspect ratio from 'original' to 'just scan' revealed the missing edges of the desktop.
Colin.
cmcconnell
Re: No Penguins?
Postby JohnR » Fri Aug 15, 2014 10:35 pm
Thanks for the reply.
I have tried fiddling with the controls on the monitor without success. There does not seem to be a control to set the aspect ratio?
Any more suggestions welcome
John.
JohnR
Re: No Penguins?
Postby cmcconnell » Fri Aug 15, 2014 11:28 pm
Colin.
cmcconnell
Re: No Penguins?
Postby JohnR » Sun Aug 17, 2014 2:31 am
I am now finally more or less in business.
After bootup and with the Parallella logo displayed, I could not still get the full Linux display but noticed there was a mostly- hidden partial bar off the bottom of the screen. After trying different Bravia settings without luck, I dragged the bar on to screen and then set its position for vertical and screen right hand position, so that now at least I can navigate.
JohnR.
JohnR
