Problem with float with OpenCL in CPU
Moderator: dar
Postby thesivis » Wed Aug 20, 2014 12:52 pm
thesivis
Re: Problem with float with OpenCL in CPU
Postby dar » Wed Aug 20, 2014 2:32 pm
Ok. This is a new one. Have not seen this before. Your tests are easy enough to reproduce on one of our boards. Let me have this looked at and I will et back to you with what I learn.
-DAR
dar
Postby dar » Sat Aug 23, 2014 12:18 pm
I tested the kernel you posted and cannot reproduce on our board. I get 3.5 for both the ARM CPU and Epiphany.
Note that you should use stdcpu for the ARM and stdacc for Epiphany. In your post you mentioned GPU and CPU.
Could you post the host code you are using for the test?
dar
Return to OpenCL
