Parallella Linux updates
Postby aolofsson » Thu Aug 21, 2014 9:31 pm
Re: Parallella Linux updates
Postby tajuma » Mon Aug 25, 2014 1:19 pm
tajuma
Postby tajuma » Wed Aug 27, 2014 12:28 pm
tajuma
Postby tajuma » Wed Aug 27, 2014 3:39 pm
tajuma
Postby greytery » Wed Aug 27, 2014 4:42 pm
Postby greytery » Wed Aug 27, 2014 9:35 pm
Postby tajuma » Thu Aug 28, 2014 5:08 pm
tajuma
Postby greytery » Thu Aug 28, 2014 6:24 pm
Makes sense that it's a bug.
Bug fixes come as workarounds, and eventually re-issue/replacement.
In this case, re-flashing the U-Boot could be done, but there's a risk of bricking the board (yeah, yeah, I know about the JTAG pins on the Samtech connectors - but I don't have any).
The U-Boot re-flash instructions would need to be simple and bullet-proof. Here's waiting...
Still cross checking the boot script workaround on my two boards, using the addresses you've identified, but it's looking good.
Whether it's garbage or not :D
Postby jimbaker » Mon Sep 01, 2014 12:21 am
Is there any way to download the source for the kernel that had HDMI working?
I've tried to figure out which 'branch' it might be, with no luck.
I was using the HDMI version and had built a modified kernel and all was well.
Then I decided to start from scratch, create a SD card, modify the kernel, etc. because I had done a lot of thrashing about trying to get the UCA222 usb sound device to work with line-in/line-out, etc., which I did ultimately get working.
However, now the how-to-build-a-kernel link pulls down the latest, where HDMI isn't working, and I'd like to get the "old" version.
jimbaker
Postby terminal3 » Thu Sep 04, 2014 4:38 pm
terminal3
