e_write/e_read confusion - Epiphany ram
Postby AndyC » Fri Aug 22, 2014 8:13 am
AndyC
Re: e_write/e_read confusion - Epiphany ram
Postby notzed » Fri Aug 22, 2014 11:28 am
e_alloc() only maps memory in the shared area.
You're reading/writing to completely different locations, not surprisingly since the arguments are completely different objects.
Postby AndyC » Fri Aug 22, 2014 11:35 am
Thanks for the info.
The e-bandwidth-test example code tests host to ERAM speed using this method, is this a different ERAM then?
AndyC
Postby notzed » Tue Aug 26, 2014 12:48 am
Postby AndyC » Wed Aug 27, 2014 1:40 pm
It was me getting confused with the naming conventions.
As far as I see it there is:
1. Host Ram
2. Shared ram
3. Epiphany local ram
I took ERAM to mean 3 where as far as I can see it is actually 2.
Cheers
Andy
AndyC
Postby notzed » Thu Aug 28, 2014 2:44 am
Yes the object in your example called "eram" is in 2, the shared memory.
Hence I would give it a more accurate and mnemonic name, like "sram" ;-) and reserve the mnemonic "eram" for e(piphany) ram.
Postby sebraa » Thu Aug 28, 2014 12:42 pm
Why not use the official terms? 8-)
- Host Memory (not really important when programming for the Epiphany, since it can't access it)
- Shared Memory or Shared DRAM (or External DRAM or DRAM, but these suggest different things to me)
- Local Memory or SRAM
They are used in the official documentation and in the linker scripts. ERAM then means "External RAM".
Postby AndyC » Thu Aug 28, 2014 12:49 pm
ERAM is not defined in the documentation at all as far as I can see.
AndyC
Postby notzed » Fri Aug 29, 2014 3:40 am
Postby sebraa » Fri Aug 29, 2014 2:32 pm
