Use MPI with Parallella Cluster
Postby Cary » Thu Aug 28, 2014 4:06 pm
Cary
Re: Use MPI with Parallella Cluster
Postby aolofsson » Thu Aug 28, 2014 6:03 pm
Please see the following post from a while back...
http://www.adapteva.com/white-papers/bu ... f-cluster/
You might need to set the path explicitly in your run program rather than in your bashrc to get it to work.
The good news is that this sudo nonsense will finally be gone in a couple of weeks time with the new SDK release :D
Postby Cary » Thu Aug 28, 2014 8:59 pm
Thanks for the reply.
I also tried setting the path explicitly but not sure of the correct syntax for setting paths with mpiexec. Everything I tried gave me errors except when I used sudo. Any idea of how the mpi call might look when add paths?
Cary
Return to MPI
