dot product
dot product
Postby aihaike » Fri Sep 05, 2014 2:05 am
Dear all,
I'm trying to run the dotproduct example but fail.
The code crash when loading the .srec binary to the board.
I'm wondering if someone has experienced the same issue.
Thank you,
Eric.
aihaike
Re: dot product
Postby manklee » Fri Sep 05, 2014 9:40 pm
I also was unable to run the dot product sample. The output I got was:
Calculating sum of products of two integer vectors of length 4096 initalized to all 0x1's using 16 Ccores.
........FAIL
Was any one able to run this demo successfully?
manklee
Re: dot product
Postby aihaike » Sat Sep 06, 2014 2:28 am
aihaike
Re: dot product
Postby manklee » Mon Sep 08, 2014 11:21 pm
I traced the program to:
e_load_group("e_task.srec", &dev, 0, 0, platform.rows, platform.cols, E_TRUE);
and that's when it crashed too!
manklee
Re: dot product
Postby aihaike » Wed Sep 10, 2014 4:18 am
I tried to modify the epiphany code and make something easy but it doesn't help.
aihaike
Re: dot product
Postby manklee » Fri Sep 12, 2014 3:08 am
Does this mean that we got defective epiphany chips?
manklee
Re: dot product
Postby aihaike » Fri Sep 12, 2014 3:10 am
No, I can run several other examples and do some stuff myself.
I but definitely need to understand what's going wrong with this code.
aihaike
Re: dot product
Postby aihaike » Mon Sep 15, 2014 8:23 am
The error code is 139, which correspond to segmentation fault.
To me e_load_group returns a segmentation fault, how is that possible?
aihaike
Re: dot product
Postby aihaike » Tue Sep 16, 2014 3:08 am
aihaike
Re: dot product
Postby manklee » Tue Sep 16, 2014 6:42 am
I know why!
You HAVE to run it in the bin directory because of this line of code:
It wants to load the array of processors with the file "e_task.srec" and you can only find it in the bin directory. I suppose if you changed the code to:
e_load_group("bin/e_task.srec", &dev, 0, 0, platform.rows, platform.cols, E_TRUE);
Then you can run it from where the shell scripts are, the "dotproduct" directory.
I ran it from the bin directory by typing
../run.sh
and I got this from the program:
All cores loaded and running
All cores done calculations.
Results copied to host
Sum of Product Is 4096!
/home/linaro/epiphany-examples/apps/dotproduct/run.sh PASSED
manklee
