u-boot version
u-boot version
Postby rjs » Fri Sep 05, 2014 11:56 am
Is the version of u-boot in the boards built from the public sources ?
I'm trying to boot a NetBSD kernel on my board but get an error that suggests that NetBSD bootm support isn't compiled in even though the symbol is defined in .
rjs
Re: u-boot version
Postby aolofsson » Fri Sep 05, 2014 12:30 pm
Yes those are the sources..this is the config file we use:
https://github.com/parallella/parallell ... rallella.h
Note that the u-boot on the current boards (and the source tree) is about 2 years old. We are currently working on updating a new boot image (with a new FSBL generated by Vivado and a new u-boot).
Re: u-boot version
Postby rjs » Fri Sep 05, 2014 8:07 pm
Would it be possible to enable CONFIG_BOOTM_NETBSD in the next official build of u-boot ?
It looks to be #undef-ed in include/configs/zynq_common.h and include/configs/zynq_cseflash.h
rjs
Re: u-boot version
Postby martin » Mon Oct 27, 2014 10:12 am
I have the same problem - but one more question: if I build my own u-boot.bin, is there some fallback/safe procedure to flash it without bricking my board?
Or if I should happen to brick it, is there a recovery procedure? Would I need a JTAG for that?
martin
Re: u-boot version
Postby 9600 » Mon Oct 27, 2014 1:36 pm
AFAIK you would need JTAG if you brick your board.
Re: u-boot version
Postby erik » Tue Apr 21, 2015 7:25 am
Not to resurrect a necro thread, but how can we go about getting NetBSD supported in the boot loader?
Kickstarter Backer #1391
NetBSD Developer, NetBSD Board Member
erik
Re: u-boot version
Postby 9600 » Tue Apr 21, 2015 11:26 am
Assuming there are no conflicts, submit a pull request?
https://github.com/parallella/parallella-uboot
Re: u-boot version
Postby aolofsson » Tue Apr 21, 2015 6:03 pm
Ola has been working on a major u-boot update for a week now...he's getting close. He will post update on forum when ready.
(when the new infrastructure is up he will also update the netbsd)
