parallella-hw fpga project structure - why?
Postby yanidubin » Sun Sep 21, 2014 5:24 am
TL;DR - Why is the repo structured the way it is? Can someone suggest a good workflow actually compatible with it? Now it may be that I am being blind and missing something and really making it hard for myself when really it is not so hard at all - if so, please lead me to the light. If not, I would like to propose a "better way", and see what issues people might see with that approach.
Disclaimer: I am not an FPGA designer, so it is possible these workflows I am rubbishing are industry standard practices - if so, please pardon my ignorance. I'm just saying they don't seem logical to me, planAhead exacerbates the problem, and I want to understand how to work with them properly.
For my own projects, I have restructured things in a way more logical to myself, using mercurial rather than git, which has worked well for me. This was in part because I far prefer mercurial to git - but also I didn't like the way the projects were structured.
So I've been putting off reconciling my workflow with the official repo - because I have something which is nice and works for me. However, now I'm wanting to give stuff back, and moreover I am writing a tutorial(s) to help others getting started - so it is important I make my peace with whatever the recommended flow is so as not to muddy the waters and raise the barrier to entry. Or, since perhaps I can make things easier, I wanted to at least suggest the solution which works for me.
The main problem I have is the way the XPS files (in particular, system.{mhs,xmp}) are located in the edk folder, with an edk folder existing for each project (each having it's own pcores). So in order to copy a project, you need to not only copy the project under fpga/projects (which you can do from planAhead), but also a project edk structure under fpga/edk (which requires a manual process - plus manual hacking of the project xml data to point to the copy). If you copy the project from within planAhead, it will not dereference the fpga/edk, and you will end up cross-contaminating projects (they all use the same XPS files - a recipe for disaster!).
It seems more logical to me that each project has its XPS files in its sources/system folder, which configures the system correctly for the purposes of that project, and determines which pcores are used - the pcores themselves remain in the edk folder, but there is no need for a project substructure to the edk folder - since various projects resuse different combinations of pcores.
Every project I have made thus far, I have needed to alter the mhs file, since I've generated and used a different pcore. And while pcores can be re-used, the combination of them, and how they are configured / mapped is unique to the project. And this is without even reconfiguring EMIO as I will be doing for my robotics projects via the Porcupine.
As I see it, planAhead has two possible behaviours when copying a project (save project as):
Option 1: don't do import all (dereference nothing outside source dir)
Good: doesn't create local copies of global includes in hdl/constraints, and pcores from edk, these remain as link.
Bad: doesn't reference system.mhs/xmp, so issues as described above with cross-contaminating projects, and git pulls start failing because you have edited the Adapteva projects and have local changes - beyond the first project, you'll start breaking past projects by changing a shared copy of the XPS files.
Option 2: import all (dereference everything outside source dir)
Good: no issues with cross contamination
Bad: creates needless copies of everything. This is a nightmare if you like minimal duplication in your source tree - plus it has a very verbose subtree structure for all these things it pulls in which is very ugly. Try navigating this to find the useful files to add to version control. I absolutely loathe this approach.
The way I have restructured my repo allows copying projects using planAhead with option 1 with no issues. The reason this works is the XPS system folder becomes a subfolder of the source dir. So when you copy a project, and it dereferences nothing outside source dir, this is no longer an issue - the XPS files are inside the source folder and get dereferenced.
In practice, (despite having a workflow which works with the UI, I am a commandline hack) I prefer doing an hg copy and fixing up one or two entries in the project file. But I'm happy to test this if you think it is a workflow worth pursuing.
Is there a bigger view here I have missed? What is wrong with my proposed approach?
I can just see my plan to write a tutorial degenerating into a treatise on working with the difficult repo structure. Because I fear the alternative would be negligently ignoring the fact that following the steps will guide people into messing up their repo and having their projects start to break.
yanidubin
Re: parallella-hw fpga project structure - why?
Postby yanidubin » Sun Sep 21, 2014 5:27 am
Also, if Vivado changes the game at all, that is probably worth considering.
yanidubin
Postby yanidubin » Mon Sep 22, 2014 11:15 pm
I have created a along these lines which perhaps explains it better.
My aim here is not to convince experts they're doing it wrong - just seeing if we can make things a little more intuitive for those getting started.
Comments/objections please?
yanidubin
Postby aolofsson » Tue Sep 23, 2014 12:18 am
Yanidubin,
Thank you for thinking though these issues and creating the blog post!!
Besides being about the Epiphany, the Parallella project has evolved into being the first introduction to FPGAs for thousands of developers. It would be awesome if we could somehow make the HW accessible to them through some sandbox project. I agree that the current method may not be ideal wrt modularity and we will certainly make sure we incorporate your inputs in the Vivado release.
Postby yanidubin » Tue Sep 23, 2014 8:06 am
Hi Andreas,
Great - thanks for that. Glad to know I'm not being over fussy :)
Yes, coincidentally designing the best thing going for FPGA development is certainly a nice problem to have. It was one of the things that drew me in actually - although I do intend to check out the Epiphany eventually.
Yani.
yanidubin
