start e-program in the subfunction
Postby howardhh » Mon Oct 13, 2014 1:33 am
Hi all,
Is there any difference between subfunction and main function, when I want to start the e-program.
Because in my program, I initialize the epiphany device in the main function, load the program into the cores in the main functionm, but I start the device in sub-function.
In this case, seems the e-program isn't executed.
While in the example program "dotproduct", it has no subfunction, and it works fine.
Does this mean I have to put all code in the main function?
Could you give me any advice? Thank you!
howardhh
Re: start e-program in the subfunction
Postby sebraa » Mon Oct 20, 2014 1:03 pm
Every C program starts in main() (excluding the magic behind the scene). So this function is where you put your code. If you want to write your code in different functions - and please do it to keep your code clean and readable - you have to call those functions yourself to run the code.
If you are not familiar with the C language, you probably want to start using it on the computer first. Then do the Epiphany details later.
