Cant find Headless Parallella in my network
Postby danbru1211 » Fri Oct 17, 2014 10:07 pm
danbru1211
Re: Cant find Headless Parallella in my network
Postby gceline » Sat Oct 18, 2014 3:39 pm
IS this a typo or did your mean parallela,bit.bit???
it should be parallella.bit.bin
two Ls and bin at the end!
Just make sure you have the right file for the board - trying the wrong one is not going to work and only can cause confusion.
Graham
Adapteva
gceline
Graham
Adapteva
gceline
Postby mjanderson235 » Mon Oct 20, 2014 1:13 am
I've been having the exact same problem as danbru1211 - the two green lights on the side of the board, along with both the green and amber lights on the ethernet port, show up with or without the SD card. The card itself would seem to have all the appropriate files (devicetree.dtb, uImage, parallela.bit.bin, everything taken from headless installs).
I can't find the board, whether I directly connect it with an ethernet cable, used a closed network with a router, or plug it into my normal wireless router. When I take the SD card out to check the files in /var/log, nothing has been written (and I made sure to change the file permissions to a+rw on the log files, just to make sure that wasn't causing a problem).
I'm waiting for cables and peripherals to connect it up via other means (didn't have either an HDMI monitor or USB keyboard), but it looks like the networking is supposed to work out of the box from what I've been seeing - is that correct? Or is it absolutely necessary via serial to start interacting with the board?
Thanks in advance for any help!
mjanderson235
Postby gceline » Mon Oct 20, 2014 10:44 pm
mjanderson235 You have the same spelling error as danbru1211 in your post
if the file is really named parallela.bit.bin then it will not boot
parallella.bit.bin ----- double l, double l
The serial will only help you see the error messages if it is not recognizing the file - but if the baord is not showing up on the network, 99% chance the board is not booting because of an error with the SD card.
Graham
Adapteva
gceline
Postby mjanderson235 » Mon Oct 20, 2014 11:15 pm
Sorry, my mistake - it is named correctly on the SD card, my keyboard here just hates double letters.
What would an error with the SD card entail? It's a perfectly new card which works fine on my laptop running Ubuntu, a Patriot 32 gig Class 10.
mjanderson235
Postby gceline » Tue Oct 21, 2014 12:26 am
The card could be bad, we recommend Sandisk because these rarely fail. However - the initial process is totally dependent on the BOOT partition having the correct files and the unit identifying these correctly
File 1:
parallella_e16_headless_gpiose_7010.bit.bin (2035 kb)
RENAMED as parallella.bit.bin
File 2
devicetree.dtb 3/6/14 7kb
File 3
uImage 2/6/14 4368kb
These are in the file kernel-headless-default.tgz (4343 kb zipped) and need to be extracted first.
Copy these cleanly - delete old versions, unplug the SD card, re-insert and make sure the old files are no longer there, and then copy/paste the files into the directory.
You should be good to go.
Graham
Adapteva
gceline
Postby mjanderson235 » Wed Oct 22, 2014 12:05 am
Nope, still not working. Went out and got a Sandisk 16 gig, burned it, tested it on a couple different Linux computers (which vetted my Patriot disk too, so the disk itself doesn't seem to be bad), still won't work. File names, dates, and sizes have been checked and rechecked. Disks have been formatted a couple times too, to make sure.
All the lights come on, the amber light on the ethernet port looks like it's doing something, I just can't find an IP address no matter what. And nothing's being written to var/log, either.
mjanderson235
Postby mjanderson235 » Wed Oct 22, 2014 1:01 am
Ok, problem solved! There's something wrong with the headless files - when I switched to the HDMI ones (even though using a headless configuration), everything worked fine.
mjanderson235
Postby gceline » Wed Oct 22, 2014 1:08 am
Great - will try and work out what is the issue with the files
Graham
Adapteva
gceline
