[ISSUE] Starting all the cores together vs. one at a time
Postby sakalisc » Wed Oct 29, 2014 1:16 pm
sakalisc
Re: [ISSUE] Starting all the cores together vs. one at a tim
Postby notzed » Wed Oct 29, 2014 10:13 pm
Looks like this. See the last couple of posts; since the sdk is nearly here it should be being looked at soon.
viewtopic.php?f=23&t=223
Postby sakalisc » Thu Oct 30, 2014 10:43 am
I run some more tests and it does look like a similar problem. I will investigate this a bit more. Thanks a lot!
EDIT: Just in case someone runs into the same problem, here is what I found:
1. Reading/writing too much data from the SHDRAM too quickly seems to cause a problem, even without DMA
2. If and only if the program is stored in the SRAM, then it works most of the time. Otherwise, it freezes/crashes.
sakalisc
