What's E_DMA_MSGMODE meaning?
Postby eliecer » Fri Nov 28, 2014 5:41 pm
dma_start_master.zip
It has comments in Spanish
(16.67 KiB) Downloaded 878 times
eliecer
Re: What's E_DMA_MSGMODE meaning?
Postby notzed » Sat Nov 29, 2014 5:34 am
This behaviour is described in Table 39 (DMACONFIG register) of the arch reference manual. Its one of the "experimental" features so not well documented I guess.
It changes when the dma is considered 'finished'. Normally the dma is marked finished when the last transaction is started since the dma engine has nothing left to do, and could start new transfers straight away (e.g. chained). But if you're writing to local memory (the only place where msgmode works) then this isn't very useful - because one or more of the DMA transfers will still be in-flight (somewhere out on the mesh network, making their way to completion).
Message mode amounts to adding another step (or annotating the last one) which amounts to tracking the last write, and when that is done the dma is marked as done. It's only valid when the target is local (16-bit address).
The fact the example only works with it own is demonstrating why it is needed - otherwise there wouldn't be any point.
PS afaict this bit has nothing to do with the MESSAGE interrupt; dma interrupts are as normal even with msgmode set (i.e. when the dma channel switches to idle). But I can't find anything in the manual at all about the message interrupt, it may just be reserved for software use.
Postby eliecer » Sat Nov 29, 2014 5:20 pm
Thank you notzed.
In the example the host writes 10 numbers in external memory. A core uses DMA for to copy this numbers in its local memory.
What do you think if I write in my documentation... "If you use DMA for to copy to local memory you need to use MSGMODE option"?
I have more questions about DMA, but this is the first.
Thank you.
eliecer
Postby notzed » Sun Nov 30, 2014 12:18 am
Well you don't have to use message mode, you just usually need a reliable way to determine if the dma is complete. You could use a sentinal value as the last word/byte, or even use a chained dma to write a status value separately. Something like this is required for external dma for example. And you wouldn't use message mode if you had multiple dma's chained. But for off-core (external or another core) to local transfers, it's a convenient way to use the dma idle status to reliably.
I guess it's up to you do decide what fits in the type of documentation you're writing. Hardware registers usually fall into "advanced" reference manual material typically.
