Proper way to get the registers from core to the host
Postby dmarquez » Tue Dec 16, 2014 10:26 pm
dmarquez
Re: Proper way to get the registers from core to the host
Postby aolofsson » Wed Dec 31, 2014 2:06 pm
Sorry for the slow reply..so ust to confirm you you are tying to run the following program in core 1,1:
1.) Read register values from core 0,0 into and place them in the variable registers (why 128?)
2.) Copy the registers[128] values to DRAM.
At first look, I think your REG_ADDRESS is wrong...(that is the address as seen from the host)
https://github.com/adapteva/epiphany-li ... B/fast.ldf
Postby dmarquez » Thu Jan 08, 2015 7:26 pm
No problem, I continue working on.
In my example, I try to read a register, from a remote core. The number 128 that you mention is a mistake, the registers count is 64.
Have you an example for reading register from a remote core?. I realize that it is not possible to read if the core is running. The core must to be halt for make the reading?
Thanks in advance,
David.
dmarquez
