Unmet dependencies while installing OpenCV
Postby nickoppen » Thu Dec 18, 2014 10:32 am
I've been attempting to install OpenCV using methods from a number of different sources. Regardless of what the method is I always seem to get the following:
The following packages have unmet dependencies:
libopencv-dev : Depends: libopencv-objdetect-dev (= 2.4.8+dfsg1-2ubuntu1) but it is not going to be installed
Depends: libopencv-highgui-dev (= 2.4.8+dfsg1-2ubuntu1) but it is not going to be installed
Depends: libopencv-legacy-dev (= 2.4.8+dfsg1-2ubuntu1) but it is not going to be installed
Depends: libopencv-contrib-dev (= 2.4.8+dfsg1-2ubuntu1) but it is not going to be installed
Depends: libopencv-videostab-dev (= 2.4.8+dfsg1-2ubuntu1) but it is not going to be installed
Depends: libopencv-superres-dev (= 2.4.8+dfsg1-2ubuntu1) but it is not going to be installed
Depends: libopencv-ocl-dev (= 2.4.8+dfsg1-2ubuntu1) but it is not going to be installed
Depends: libcv-dev (= 2.4.8+dfsg1-2ubuntu1) but it is not going to be installed
Depends: libhighgui-dev (= 2.4.8+dfsg1-2ubuntu1) but it is not going to be installed
Depends: libcvaux-dev (= 2.4.8+dfsg1-2ubuntu1) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
I don't understand how the linux package system works. Is this a problem on my side or is there a database out there somewhere that wired correctly?
nick
nickoppen
Re: Unmet dependencies while installing OpenCV
Postby 9600 » Thu Dec 18, 2014 1:10 pm
Postby nickoppen » Fri Dec 19, 2014 4:36 am
Thanks Andrew. That did the trick. The only thing that aptitude threw up that seemed to be odd was that one package needed to be downgraded. After I applied that fix it went in ok as far as I can see.
nick
nickoppen
Postby BOBNINO » Sat Mar 14, 2015 6:15 pm
didnt work for me i still get
libgtk2.0-dev : Depends: libpango1.0-dev (>= 1.20) but it is not going to be installed
Depends: libcairo2-dev (>= 1.6.4-6.1) but it is not going to be installed
any suggestions??
BOBNINO
Postby 9600 » Sun Mar 15, 2015 4:16 pm
Postby BOBNINO » Sun Mar 15, 2015 11:55 pm
sorry for posting this question in another forum andrew (was desperate), ill try your suggestion and get back to you .
BOBNINO
Postby Claggy » Tue Mar 17, 2015 8:41 pm
Claggy
Users browsing this forum: No registered users and 29 guests
