Nothing happen on my Parallella
Postby jimmystone » Sun Jan 04, 2015 4:01 pm
jimmystone
Re: Nothing happen on my Parallella
Postby 9600 » Sun Jan 04, 2015 4:23 pm
If you're using the HDMI versions of the files on BOOT, and you can login over SSH but don't get anything displayed on an attached monitor, I would first try using a different monitor. Some have found that certain monitors don't support the default resolution.
If this turns out to be the case and you want to use a monitor that does not support the default resolution, it is possible to .
Postby jimmystone » Mon Jan 05, 2015 3:17 pm
jimmystone
Postby 9600 » Mon Jan 05, 2015 5:33 pm
Glad to hear you are now up and running with a monitor! As to why it didn't work with a DVI one and an adapter, I couldn't say, although I do believe that this sort of issue is not entirely uncommon and may well not be specific to Parallella.
