Headless login
Headless login
Postby sting » Sun Feb 08, 2015 7:13 pm
I have been using my parallella on a headed installation and want to build an sdcard for a headless version so I can play with both. On the headed version I created a fixed ip address to work on my network. I deleted the fixed ip address from my router for the headless version until I can ssh into it and reset the fixed ip.
The trouble is I cannot see the mac address of the parallella on my router so I cannot ssh into it to do anything.
My network is 192.168.1.xxx, is the parallella looking for 192.168.0.xxx
sting
Re: Headless login
Postby 9600 » Mon Feb 09, 2015 9:15 am
For headless use can you try using this alternate devicetree:
http://forums.parallella.org/viewtopic. ... 037#p10037
Re: Headless login
Postby sting » Tue Feb 10, 2015 2:26 am
That is the device tree I was using.
I just took the three files from the headed card and copied them on the card I want to use for headless system and I could see the ip address on my router. If I copy the headless files there then I cannot see it.
sting
Re: Headless login
Postby 9600 » Tue Feb 10, 2015 2:06 pm
