Fedora 21
Fedora 21
Postby yeo » Fri Feb 13, 2015 4:10 pm
yeo
Re: Fedora 21
Postby aolofsson » Fri Feb 13, 2015 5:01 pm
yeo,
That's awesome!! Could you give some more info about the kernel you used? Where did you get the sources from? Configuration? [edit: never mind...read to the end] Can you just confirm that the linux tree was from the Parallella github?
Re: Fedora 21
Postby yeo » Fri Feb 13, 2015 6:27 pm
I built kernel as you described in . I this you should 'lock' this topic BTW because it's very useful.
The source was from parallella-linux github, right. All went smoothly.
It would be nice to enable all CGROUPS setting in parallella kernel, so people will be able to boot Fedora with your kernel.
yeo
Re: Fedora 21
Postby theover » Fri Feb 13, 2015 9:33 pm
Fedora on the Epiphany, yeah!
Re: Fedora 21
Postby lighta » Fri May 08, 2015 5:22 pm
lighta
Re: Fedora 21
Postby JoshuaPK » Sun Jun 21, 2015 7:09 pm
This is great! I'm expecting a Parallella board, and I'm planning to (try to) install RedSleeve Enterprise Linux 7. Like RHEL7, RedSleeve is based on Fedora 19, so I'm looking forward to getting this running!
JoshuaPK
Re: Fedora 21
Postby JoshuaPK » Thu Jun 25, 2015 12:59 am
JoshuaPK
