Shorted USB port
Shorted USB port
Postby jvff » Sat Feb 21, 2015 5:20 pm
Unfortunately, I managed to short my Micro-USB port (beside the Mini-HDMI port), and the board immediately turned off and won't turn on again. I used a digital multimeter to measure the resistence of F1, and nothing registers. I assume it has blown? Is there a way to test to see if this is the cause and if there's any more damage? If this is the only damage, is there a way to replace the fuse?
Thanks for any ideas,
Janito
jvff
Re: Shorted USB port
Postby 9600 » Sun Feb 22, 2015 11:14 am
I'm guessing you'd need to replace the fuse, or else short it out. Which is going to require some handy work with a soldering iron or possibly a hot air gun. All of which involves an element of risk, of course, but then if the board is presently dead...
However, I'd suggest waiting to see if anyone else has any other ideas before diving in.
Postby jvff » Mon Feb 23, 2015 2:11 pm
ok, thanks. I'll see this week if I can short the fuse to see if the board boots up again.
Janito
jvff
Postby 9600 » Mon Feb 23, 2015 8:19 pm
OK, but be mindful of the fact that shorting the fuse and applying power could make matters worse if there is an unresolved problem downstream of this!
Postby jvff » Thu May 14, 2015 2:05 pm
just to post the conclusion: it worked! I soldered a new fuse to it (part ERB-RE4R00V) and it's working normally. For future reference: if you short your USB port, the fuse will blow.
Thanks for the help!
Janito
jvff
Postby 9600 » Thu May 14, 2015 3:30 pm
Phew, glad to hear that you are back up and running, Janito! :D
