Epiphany/ARM programming
Postby Nader_Jendoubi » Tue Feb 24, 2015 3:26 pm
hi
i'm new in parallella and i wanna ask:
Should i use emac24 or another program to write epiphany and ARM cores C programs??
How to generate projects like those of "parallella examples" and "epiphany example"
How compile C project using gcc for ARM and e-gcc for epiphany??
Is it necessary to write shell scripts to run epiphany and ARM core programs??
I need really answers to my questions because i have a ARM/epiphany projects and i must know everything about programming and compiling in Linux
Nader_Jendoubi
Re: Epiphany/ARM programming
Postby sebraa » Tue Feb 24, 2015 4:50 pm
You need to understand first yourself. Start with the SDK documentation [0] and the architecture reference [1].
Also, you are asking the wrong question, and answering your question does not help you.
> I use "vim" and "make".
> You can use "emacs" and "bash".
> Others might use "nano" and "perl".
> If you are up for a challenge, try to use Microsoft Word and Microsoft Visual Studio.
You need to understand what needs to be done, and (to a lesser degree) why it needs to be done. Then you can start asking questions about how it should be done. There is many possibilities, but no best solution.
[0]
[1]
