New improved SD images (Beta testers needed!!!!)
Postby aolofsson » Fri Mar 06, 2015 11:00 pm
Re: New improved SD images (Beta testers needed!!!!)
Postby adexmont » Sat Mar 07, 2015 9:33 am
Postby Frida » Sat Mar 07, 2015 4:18 pm
Frida
Postby aolofsson » Sat Mar 07, 2015 5:01 pm
Frida,
Thank you!! Big fail on my part.,,got side tracked and forgot to test that link..should be fixed now.
Postby pgater » Sun Mar 08, 2015 12:45 pm
Saw your request for people to test the image and thought I would try it! 8-) Downloaded the headless 7020 image, as I have given up with the monitor a long time back and it is more convenient using one keyboard and mouse.
1. Using Windows (Vista 64 bit ultimate in this case) the new procedure is a doddle, even for a Linux noob such as myself and I like this a lot :D :D 8-)
I think the original image was done this way! Just as importantly, it worked first time 'out of the box' with a Kickstarter board :D :D :D :D
2. I logged in using WinSCP so I could look around the files. I also logged in to the command line using Putty and ran top, so I could see what was going on. After an hour I put a thermocouple on the Zync heatsink and connected to my multimeter to monitor the temperature. I monitored the temperature for an hour and it was 45 degrees C. Took a deep breath and switched off the fans :o The temperature went up to 55 degrees C fairly quickly, but after half an hour showed no signs of increasing, so I put the fans back on and shutdown.
The temperature daemon is a great idea :D and will give peace of mind :D
3. Cannot comment about power consumption, do not know how to measure it. :?:
4. See 2, with top I could see the daemon operating. Will try running some programs to increase the load and temperature.
5. Pubuntu? Not sure, as Pub in English means some thing entirely different, ie where food (sometimes) and alcohol are consumed :lol:
Some other observations :-
I have found that sudo is still needed :?
On the old image I could access an X terminal, but currently cannot with the new image :? This is probably down to me, but not sure. :?
Incidentally, (and slightly off topic) I am sure all of the Linux noobs (such as me) would appreciate some guidance on accessing X and running the desktop remotely in the instructions :geek:
Keep up the good work!! :D :D :D :D :D :D :D
Paul
pgater
Postby aolofsson » Tue Mar 10, 2015 1:31 pm
Paul,
Thanks for the feedback and the encouragement!!!
Postby greytery » Fri Mar 13, 2015 7:23 pm
Postby mikebell » Fri Mar 13, 2015 11:18 pm
I've just got the 2015.01 sd card running - all looks good so far.
One thing I noticed though - step 5 in the getting started guide still says linaro / linaro as user / password.
mikebell
Postby mikebell » Sat Mar 14, 2015 3:12 pm
mikebell
Postby aolofsson » Mon Mar 16, 2015 12:07 pm
Mike,
-Are you saying the board ran fine before and now is flaky?
-Are you runnning the complete new SDK image, or just the new sdk?
-How are you cooling the board?
Thanks for reporting this! We will get this resolved asap! Will come back a couple of more things today to let you modify frequency and voltage.
