Issue with linker and memcpy()
Postby cmcconnell » Sat Mar 07, 2015 8:34 pm
Colin.
cmcconnell
Re: Issue with linker and memcpy()
Postby cmcconnell » Sat Mar 07, 2015 10:07 pm
Colin.
cmcconnell
Postby mikebell » Sun Mar 08, 2015 12:08 am
I got confused by this too, and spent a while fruitlessly messing with the linker files - I'm sure I'll work them out eventually, but I haven't yet!
Anyway - the reason for memcpy getting called is that gcc decides that you have a loop that it thinks would be more efficient if it was done by memcpy. It seems on Epiphany this is generally wrong. To disable this behavior add the -fno-tree-loop-distribute-patterns option to gcc.
Mike
mikebell
Postby sebraa » Mon Mar 09, 2015 2:32 pm
It is not a bug of gcc, but intended behaviour.
gcc will emit function calls to memcpy, memmove, memset and memcmp by default. This cannot be disabled as such, but if you provide the -fno-tree-loop-distribute-patterns option, you disable the optimization detecting this condition.
Postby cmcconnell » Mon Mar 09, 2015 3:28 pm
Colin.
cmcconnell
Postby cmcconnell » Tue Mar 10, 2015 2:44 am
Colin.
cmcconnell
