Image processing library with epiphany
Moderator: dar
Postby Nader_Jendoubi » Mon Apr 06, 2015 4:56 pm
Hi
Either openCV (what i can use just with ARM), Does exist any image processing library what i can use on the epiphany chip because i have to implement a harris corner detector application to execute in the epiphany (with openCV functions in the host) and it's really difficult to do it manually . What advices can be given ??
Nader
Nader_Jendoubi
Re: Image processing library with epiphany
Postby 9600 » Tue Apr 07, 2015 8:02 am
HI Nader,
As far as I am aware there is no existing image processing library that has been ported to Epiphany, I suspect that repeatedly posting the same question is not going to help you, and that this is going to require some effort on your behalf.
Postby nickoppen » Tue Apr 07, 2015 11:38 am
Nader,
Have you seen this: . It looks to me as if you are not the only one thinking of this.
Using OpenCL on the Epiphany you have different issues to solve than on a GPU but right at the moment, it seems that solving those problems is where we are up to. If you want to have a go at the corner detection algorithm you need to come to grips with all of the issues surrounding getting the data stored in the OpenCV data structures onto the Epiphany and reworking the algorithms to take advantage of the chip's strengths. The work that the OpenCV community is currently doing will get you some of the way there but to get over the line, you'll need to get your own brain cells cranked up.
And when you are done, please write a blog post entitled, "OpenCV on the Epiphany - Porting and expanding modules". I'd be fascinated to read it.
nick
nickoppen
Return to OpenCL
