JTAG and SRST
JTAG and SRST
Postby afy » Wed Apr 29, 2015 11:45 am
It seems it's not possible to reset the Zynq SoC via JTAG? The Zynq's PS_SRST_B pin is connected directly to 1.8V according to the Parallella schematics, and the Porcupine schematics have JTAG pin 14 (which is SRST on the Digilent JTAG-HS3 adapter) as not connected.
If that diagnosis is correct, might it be possible to route that pin in future Porcupine and/or Parallella board revisions?
afy
Re: JTAG and SRST
Postby aolofsson » Mon May 18, 2015 10:16 pm
Andreas,
If this is indeed a must have, then we will certainly implement it on the next version. Are you sure this is actually needed to operate correctly?
In the past, we did a "soft reset" once connected with the JTAG cable.
Re: JTAG and SRST
Postby greytery » Thu May 21, 2015 10:12 am
Andreas,
Sadly, from experience, I think it is a MUST HAVE to provide access to the JTAG pins other than via the PEC Power/Porcupine connectors.
Best as pins (like the UART). May not be enough space for the full JTAG header as implemented on the Porcupine - but at least let the pins be accessible via pads.
Bricked Microservers - or boards without the Samtec sockets - have no realistic way back. :cry:
