Software defined radio
Moderator: tjt7a
Postby yonidavidson » Fri May 15, 2015 10:46 am
I represent a team of researchers.
We are planning on building a software defined radio (Reciever only) based on the Parallella platform.
I would like to connect an Analogto Digital convertor with a high sampling rate, unfortunally most of them are pcie commonication based.
I can live with some latency but I think that connecting to the Parallela FGPA will be possible to get a high thrupout connection .
Does anyone have experience with any of this ?
Thanks,,
Yoni
yonidavidson
Re: Software defined radio
Postby 9600 » Fri May 15, 2015 12:56 pm
A Myriad-RF design has been done which may be of interest:
https://myriadrf.org/projects/parallella-rf/
To the best of my knowledge this has not been manufactured as yet, although . And it's really just a variation on the tried and tested Myriad-RF 1 module, so in theory there shouldn't be any surprises, assuming the Parallella interface side is all correct.
Postby yonidavidson » Sat May 16, 2015 8:10 am
Thanks for the quick answer.
I see in your previews posts that when using Parallella in Headless configuration , you can expand more ports on the FGPA.
You have written that you are working on extending more ports this way.
"Finally, a peripheral-rich “megaio” configuration is also in the works, which will provide second Ethernet (external PHY required), I2C and UART ports, plus SPI and CAN bus."
http://forums.parallella.org/viewtopic. ... 1154#p7248
Have you succeeded creating any high speed ports this way ?
All i need is an high speed port to connect the A2D , I can manage the latency needed to transform the data from the host.
Y
yonidavidson
Postby yonidavidson » Sat May 16, 2015 9:23 am
Based on this :
http://www.parallac.org/#contact
I think that I might just use a bridge to connect my A2D to an external storage device to keep the data and connect them both to a Parallela board for processing,
Does do you any problem with this Architecture ?
As I said before , I don't mind the latency and since my data input will be much bigger then my processing skill I'll need an external storage for buffer.
Y
yonidavidson
Postby 9600 » Sat May 16, 2015 10:58 am
