How to compile with PAL libraries
Postby cardosojc » Tue Jun 02, 2015 9:36 pm
In https://github.com/parallella/pal/blob/master/README.md, there is an example of PAL usage but there is no reference to how to compile the files.
Can someone post here how should i proceed in order to execute the example?
Thanks!
cardosojc
Re: How to compile with PAL libraries
Postby aolofsson » Tue Jun 02, 2015 11:25 pm
Huh? There are make, config instructions right there?
What exactly is missing?
Postby cardosojc » Wed Jun 03, 2015 6:31 am
I'm speaking of hello_task code, how to compile it!
cardosojc
Postby cardosojc » Fri Jun 05, 2015 10:18 pm
What i need is an example of the build script, one considering pal libraries and includes.
cardosojc
Postby cardosojc » Sat Jun 06, 2015 10:31 pm
I have this script:
#!/bin/bash
set -e
ESDK=${EPIPHANY_HOME}
EINCS=${ESDK}/tools/host/include
ELDF=${ESDK}/bsps/current/fast.ldf
ELIBS=/home/parallella/pal/src/.libs:${ESDK}/tools/host/lib:${LD_LIBRARY_PATH}
EHDF=${EPIPHANY_HDF}
SCRIPT=$(readlink -f "$0")
EXEPATH=$(dirname "$SCRIPT")
cd $EXEPATH
CROSS_PREFIX=
case $(uname -p) in
arm*)
# Use native arm compiler (no cross prefix)
CROSS_PREFIX=
# Use cross compiler
CROSS_PREFIX="arm-linux-gnueabihf-"
esac
# Build HOST side application
${CROSS_PREFIX}gcc src/hello_arm.c -o bin/hello_world.elf -I ${EINCS} -L ${ELIBS} -le-hal -le-loader
# Build DEVICE side program
e-gcc -T ${ELDF} src/hello_epiphany.c -o bin/e_hello_world.elf -le-lib
# Convert ebinary to SREC file
e-objcopy --srec-forceS3 --output-target srec bin/e_hello_world.elf bin/hello_world.srec
But on line "${CROSS_PREFIX}gcc src/hello_arm.c -o bin/hello_world.elf -I ${EINCS} -L ${ELIBS} -le-hal -le-loader" the compilation fails with the error :"/usr/bin/ld: cannot find -le-hal /usr/bin/ld: cannot find -le-loader"
What i'm doing wrong? Thanks!
cardosojc
Postby paran » Fri Jun 12, 2015 3:09 am
paran
Postby cardosojc » Fri Jun 12, 2015 1:05 pm
Perhaps i'm not explaining myself correctly...I was able to build pal master from git.
I'm trying to write my own program using pal libraries but i cannot compile it!
cardosojc
Postby paran » Sat Jun 13, 2015 1:43 pm
Do you mean you dont have a compiler or c++ IDE?
use synaptic package manager to download Code::Block.
Access Hello_Task with Code::Block and compile/run it. If you can and cannot compile your own code, then something wrong with your code.
paran
Postby paran » Sat Jun 13, 2015 1:49 pm
paran
Postby njpacoma » Mon Jul 06, 2015 3:54 am
I am confused in the same way as cardosojc.
I followed the PAL build instructions and also ran a "sudo make install" because that didn't seem to get done after the "make". That seemed to be successful.
I have taken the example code from the PAL README.md and moved that code to a 'workarea' directory:
workarea/palExample
manager.c
hello_task.c
and now I want to compile them. Whatever I have tried so far does not work.
Using the build commands from another example, the epiphany-examples/apps/hello-world, I have a compile command for the manager.c file like this
gcc manager.c -o manager.elf -I /usr/local/include/pal -L /usr/local/lib -Ilibpal
but what I get out is as follows:
manager.c: In function ‘main’:
manager.c:30:9: warning: passing argument 6 of ‘p_run’ from incompatible pointer type [enabled by default]
status = p_run(prog0, team0, i, 1, nargs, args, 0);
In file included from /usr/local/include/pal/pal.h:3:0,
from manager.c:1:
/usr/local/include/pal/pal_base.h:107:5: note: expected ‘const char **’ but argument is of type ‘char **’
int p_run(p_prog_t prog, p_team_t team, int start, int count, int nargs,
/usr/bin/ld: cannot find -llibpal
So, I am obviously missing something here.
Similarly, I am not sure how I would go about creating the hello_task.elf file that the manager.c program wants to load into the processors.
Can you point me in the right direction?
njpacoma
