Added "Hello World" example to sdk git
Postby ysapir » Sun Apr 07, 2013 5:51 pm
Just added a "Hello World" example to the epiphany-sdk repository.
This is much simpler than the "matmul" example and shows very basic concepts of setting up a host-device application and message passing.
cannot find e-hal error !!
Postby anupkini » Tue Apr 09, 2013 11:19 pm
Hi Yaniv,
Thanks for the hello_world example.
I built the e-gcc and epiphany-sdk from source successfully a while ago.
When i try to run the build script from hello_world, i end up with the following error.
/usr/bin/ld: cannot find -le-hal
collect2: ld returned 1 exit status.
This is the part that compiles the host code. I am running the build.sh from the Zedboard and not my laptop :?
Let me know if i am doing something wrong
anupkini
Re: Added "Hello World" example to sdk git
Postby ysapir » Tue Apr 09, 2013 11:37 pm
1. Please make sure your EPIPHANY_HOME environment variable is set correctly (normally, /opt/adapteva/esdk ).
2. Add:
echo $EPIPHANY_HOME
echo $ESDK
echo $ELIBS
echo $EHDF
to the run.sh script (or just "set -x") to see if variables are set correctly.
3. Look if the libe-hal.so file is at "$EPIPHANY_HOME/tools/host/lib".
Postby anupkini » Wed Apr 10, 2013 12:24 am
Fixed it !!
I had to change epiphany_libs/build.sh file to point to the 16 core version BSP.
Also, in the run script the EHDF=${EPIPHANY_HDF} , was pointing to null location.
Changed it to point to current/*.hdf,
Thanks for pointing me to the solution.
anupkini
