Parallella cluster with jetson tk1?
Postby pradeep » Tue Jun 09, 2015 12:24 pm
Since parallella has super CPU with 16- accelerator chips
Can it be clustered with jetson tk1 ? So that all CPU wrk will be done by parallella and GPU work by TK1? :D
pradeep
Re: Parallella cluster with jetson tk1?
Postby 9600 » Tue Jun 09, 2015 2:01 pm
Of course, if you write the software.
Postby pradeep » Tue Jun 09, 2015 3:06 pm
They said there is a version of open MPI which supports both GPU and CPU . can i use this ? Like parallella supports right?
pradeep
Postby sebraa » Tue Jun 09, 2015 5:02 pm
The MPI implementation for Parallella works slightly different than other implementations. You can keep your MPI-based kernel, but the surrounding code needs to be ported.
