Pre-fetch
Pre-fetch
Postby tnt » Thu Apr 25, 2013 7:41 pm
If you ever do an ISA revision, something that could help 'stream' processing is a pre-fetch instruction.
Basically, you just do a "fetch [addr]" and this is non-blocking, just issues a read request. When the result comes back, it's pushed in a small fifo (only need a few elements depth) and then you have another instruction to read from that fifo with ver low latency.
This would allow to hide external fetch latency without using the DMA. Sometimes you don't know addr "much" in advance and doing a DMA of like 16 words is a bit of a waste of time. When using the DMA for "large" chunks, you also need to dedicate space for a "ping-pong" buffer which makes you loose some precious space.
Just a thought for the future.
Sylvain
Re: Pre-fetch
Postby EggBaconAndSpam » Tue Jul 16, 2013 8:13 pm
Another, more straightforward, idea would be to make loads non-blocking, that is simply claim the target register until the write returns, don't block the pipeline prematurely...
(might be a lot more difficult than it sounds, I am not all that familiar with circuit design)
EggBaconAndSpam
Re: Pre-fetch
Postby tnt » Tue Jul 16, 2013 9:46 pm
Yeah, it would be more difficult to do in HW because you'd need a bunch of logic to keep track of register dependency.
While with a fetch you just issue a read on a address in the emesh with a return address being in the 'register' zone and that poins to some small hardware FIFO.
Re: Pre-fetch
Postby timpart » Wed Jul 17, 2013 6:28 am
