Can I use Parallella as a Server?
Postby c1d » Tue Apr 30, 2013 2:34 pm
Once I heard about the 16 core CPU I knew I wanted to use Computing Power for a Server. I'm currently running my own server program that requires loads of Computing Power and I wanted to know if I could use Parallella as a server. If I can that would be great since its Cheap, Easy to setup, Amazing Power and low wattage!
@_C1D
c1d
Re: Can I use Parallella as a Server?
Postby 9600 » Tue Apr 30, 2013 3:31 pm
Postby c1d » Tue Apr 30, 2013 3:56 pm
Its a WebSockets chat server, written in node.js (Will that be compatible). It needs a better processor so it can run the checks I do over each WS message (To see what type of message is sent and where I should route it to) and then relay it in the correct way, faster.
c1d
Postby 9600 » Tue Apr 30, 2013 4:33 pm
