Memory transfer benchmark
Postby tnt » Thu May 02, 2013 6:43 pm
Has anyone done benchmark from core to/from external DRAM ?
I thought I had seen some a few months ago but can't find them ...
Sylvain
Re: Memory transfer benchmark
Postby ysapir » Thu May 02, 2013 8:19 pm
Postby tnt » Thu May 02, 2013 9:30 pm
Thanks, that's consistent with what I get ( 87 Mo/s read , 234 Mo/s write ).
But that's pretty low, the interface peak is supposed to be like 900 Mo/s right ?
Postby ysapir » Thu May 02, 2013 10:02 pm
Please note that the host transfer speeds were measured using memcpy() calls (which is the implementation of the e_read() and e_write() API's). You can probably get better performance using DMA.
Postby tnt » Thu May 02, 2013 10:05 pm
Postby ysapir » Thu May 02, 2013 11:10 pm
Yes.
Postby shodruk » Fri May 03, 2013 1:57 pm
Hmm... Host <-> ERAM bandwidth is strangely slow.
What is the Zynq's DDR configuration (operating frequency, DRAM bus width) ?
Postby ysapir » Fri May 03, 2013 8:56 pm
I added a section to the test, measuring the memcpy() speed withing application space (virtual memory). It happens that memcpy() between buffers within the host application (i.e., virtual to virtual space, insode the O/S DRAM segment) achieve speeds of 240 MBps.
This is about 2x the speed of DRAM to/from ERAM (reminder: ERAM here is the segment of the board's DRAM dedicated to the Epiphany and not seen by linux). I am open to explanations on *why* the two operations are so different in speeds.
Looking at the memcpy() disassembly code, it looks like the copy is done via reg read/write and not DMA.
Regarding the ZedBoard's spec - according to Roman, the default ZedBoard configuration is 533MHz Operating Frequency, 32bit effective DRAM bus width, which means ~2 GBps. However, we will look further on the documentation to see if the actual settings we have is different.
Postby tnt » Fri May 03, 2013 9:17 pm
Postby shodruk » Thu Jun 20, 2013 4:57 am
Is this understanding about eLink correct?
eLink packet size is always 104 bits.
(data:32, src_address:32, dst_address:32, control:8)
Writing 32 bits costs 104 bps of bandwidth.
Reading 32 bits costs 208 bps of bandwidth.
(104 bits for request, 104 bits for response)
