Any image of the new ESDK in Desktop?
Postby MiguelTasende » Thu Jul 16, 2015 8:52 pm
Hi!
I wanted to know if anyone has a "Desktop" image with the latest ESDK.
I suppose I could try to upgrade the SDK in the current Desktop image or "desktopify" a current Microserver image, but as my first attempt at upgrading the SDK failed by now, and I am working on getting some cluster work with the Epiphanys, it would be a "delayed job", and if someone has already done it, could be very helpful.
The problem, in fact is this:
I have 1 parallella desktop and 2 paralllella microserver.
I configured them in a cluster. I use MPI between nodes, and the ESDK inside the nodes. The problem is that I can't make the 3 nodes work because they have different versions of the ESDK.
I can have a 3 node ARM cluster, or a 2 node ARM-Epiphany cluster, but I want a 3 node ARM-Epiphany cluster :)
MiguelTasende
Re: Any image of the new ESDK in Desktop?
Postby tnt » Thu Jul 16, 2015 9:12 pm
I thin someone tried but didn't workout.
AFAIK the FPGA image with video support uses the old e-link logic which isn't compatible with the new SDK.
Postby aolofsson » Thu Jul 16, 2015 10:33 pm
The quickest way would be to run all systems headless and login to them from your laptop. Both microserver and desktop can use the same image.
https://www.parallella.org/create-sdcard/
