Debug halt from command line?
Postby markd » Fri Aug 28, 2015 3:57 pm
I'm trying to put the Epiphany chip into a debug halt state using e-write, and it doesn't seem to be working.
If I understand correctly, writing a one to E_REG_DEBUGCMD should work
e-write 0 0 0xf0448 1
And then the E_REG_DEBUGSTATUS register should reflect that with a 1 in bit 0. But it returns 0 instead:
parallella@parallella:~$ e-read 0 0 0xf040c
[0x000f040c] = 0x00000000
(I had written an infinite loop and run it on core 0 0 prior to trying the debug break)
Also using e-read on almost any register returns 0 (including E_REG_PC) while running an example
I'm running ubuntu-14.04-headless-z7010-20150130.1.img
markd
Re: Debug halt from command line?
Postby sebraa » Fri Aug 28, 2015 4:39 pm
