Snappy Ubuntu on Parallella
Postby Almaz » Tue Sep 08, 2015 7:32 am
Hi Parallella Gurus!
We using Linaro and Ubuntu images for Parallella
And we want to install Ubuntu Snappy on Parallella
How can we install and use Snappy Ubuntu on Parallella?
sincerely, Almaz
Almaz
Re: Snappy Ubuntu on Parallella
Postby sebraa » Tue Sep 08, 2015 12:36 pm
The SD card uses two partitions: "BOOT" (which is FAT formatted) and rootfs (which uses the ext4 file system). You can replace the rootfs partition with any other distribution's root file system, if this distribution is able to run with the Parallella kernel. However, this requires some knowledge on how a Linux distribution works, and it won't give you all the niceties of a real Ubuntu installation on a PC. This is due to the fact that the Parallella kernel is a customized kernel and the Parallella boots in a different way than your average PC.
Oh, and without installing the eSDK manually, you'd lose access to the Epiphany chip on the Parallella.
Postby Almaz » Tue Sep 08, 2015 12:59 pm
thanks,
I burn snappy image on mmc and below output of lsblk:
mmcblk0 179:0 0 14,5G 0 disk
├─mmcblk0p1 179:1 0 4M 0 part
├─mmcblk0p2 179:2 0 64M 0 part
├─mmcblk0p3 179:3 0 1G 0 part /media/almaz/system-a
├─mmcblk0p4 179:4 0 1G 0 part /media/almaz/system-b1
└─mmcblk0p5 179:5 0 5,2G 0 part /media/almaz/writable
And tryed to boot parallella following https://ograblog.wordpress.com/2015/01/ ... mhf-board/ and text file http://people.canonical.com/~ogra/snapp ... system.txt
And couldn't load. I edited above text file for boot. but it didn't help.
Can you help with proper commands for zynq uboot ?
Almaz
Postby sebraa » Tue Sep 08, 2015 1:20 pm
As I wrote, you need to replace the rootfs partition, not the BOOT partition.
For the U-Boot logic... you might want to connect a serial port and do the research yourself. The Snappy boot system looks a bit complex, so you'd need to port that over.
Postby Almaz » Wed Sep 09, 2015 4:05 am
thanks for reply
if you have any links with experience Snappy Ubuntu on Parallella,
please, provide me
Almaz
Postby Almaz » Thu Sep 10, 2015 9:30 am
found that main boot file is snappy-system.txt located in boot partition ( https://ograblog.wordpress.com/2015/01/ ... mhf-board/ )
tried to boot similar to manual for raspberry http://people.canonical.com/~lool/rpi2/README.txt
and could't boot,
it seems we need something different for parallella
Almaz
