Login Problem
Login Problem
Postby OlivierB » Wed Oct 07, 2015 11:49 am
Greetings,
I have just finished installing all needed cables for a headless configuration. I found the Parallella board's IP address with the Advanced IP Scanner. Now, when I try to login with Putty (using an SSH session on port 22), the login fails. I am using linaro as user name and linaro as password.
Any suggestions?
Olivier
OlivierB
Re: Login Problem
Postby sebraa » Wed Oct 07, 2015 12:34 pm
Older images used "linaro", newer images use "parallella".
Try to log in with "parallella" as both username and password.
Re: Login Problem
Postby OlivierB » Wed Oct 07, 2015 12:42 pm
thanks a lot!
Olivier
OlivierB
