A version of Python for Epiphany
Postby polas » Fri Oct 16, 2015 9:22 am
polas
Re: A version of Python for Epiphany
Postby aolofsson » Fri Oct 16, 2015 3:54 pm
This is brilliant! Well done! I will spread the word, hopefully it will help some folks get over the "fear of parallel" hurdle.
Postby polas » Fri Oct 16, 2015 4:19 pm
Great, I also popped up a guide to writing and running your own code on the Epiphany cores, novice to stuff running in less than 60 seconds.
This is at viewtopic.php?f=49&t=3249
polas
Postby aolofsson » Thu Nov 05, 2015 2:39 pm
Nick,
Same request I made to Jan :D
Do you think you can place a small "hello world" example in the parallella_examples directory for epython?
It should include a build/run script and indications of any pre requisites.(like git clone, build your epython repo)
https://github.com/parallella/parallella-examples
Postby MiguelTasende » Mon Nov 16, 2015 2:20 pm
This looks totally amazing!
I am testing it now, and I can't believe how easy it is to use.
I would like to know a bit more about "how does it work"?
That is to try to guess how good the performance would be in different scenarios, and get to know the limitations of the library (and possibly enhance it or improve it, if I can). I will look at the source code and try to find out, but if you could give any "big picture" ideas about the "hidden magic", would be great.
Anyway (performance or not), congratulations! Looks like a great work!
In fact I've been developing some software in C with ESDK, but now I will try the epython and consider switching... (may keep both tools at hand, also, will see...).
MiguelTasende
Postby MiguelTasende » Tue Nov 17, 2015 1:47 pm
MiguelTasende
Postby polas » Wed Nov 18, 2015 11:15 pm
Great, thanks for trying it, posting bugs and especially posting some code :) The code is very much beta and I will look into & fix the issue around host to device communication issue you mentioned for p2p & bcast. Please let me know of any other issues you find.
Yes, for the host id from a device that is a good point, I suppose the solution would be for me to add a num_device_cores and num_host_cores call (which should be quite trivial) and then a mapping function which translates the relative host id to the absolute core id (which always follow the device ids.)
Due to the limits of memory per core in the Epiphany, it does the lexing & parsing on the host (using Flex & Bison) to "compile" into a byte code representation (which can be written out via command line args.) This is designed to have as small a memory footprint as possible and is transferred onto the device via memory copy. The device (and host threads if selected) are running an interpreter which then executes the byte code itself. An additional thread on the host is a "monitor" device cores can communicate with this via a memory copy to do I/O, maths functions such as cos,tan etc (as we don't want to put maths library onto cores), string handling etc... By default it tries to put the variable values in core memory too, but for big arrays this is not always possible. There is some logic to switch the variables and/or byte code into shared memory (which can be done explicitly via command line switches too) if it doesn't fit into the device memory but this is obviously at a performance penalty (it is quite noticeable actually, and ePython provides a timing command line option where you can see the impact of this.)
In terms of performance, it is currently quite slow - but the whole idea with it is education and to get people really quickly writing parallel code and running it on this architecture. I could imagine that, based on this, they would then explore some other tools and build on the initial knowledge gained. I think there are plenty of places where the code could be sped up, and lots of additional functionality which could be added too.
Nick
polas
Postby gartor » Fri Dec 11, 2015 7:30 pm
Sorry This is taking a lot longer than 60 seconds.
What should EPIPHANY_DEV be set to?
Is the Epiphany Shared Memory Manager only available on the headless kernel?
I'm not using the headless kernel. How do I start it?
linaro@linaro-nano:~/epython$ ./epython.sh -d 5 hello.py
epython-host: e_init(): EPIPHANY_DEV file open failure.
epython-host: e_init(): Failed to initialize the Epiphany Shared Memory Manager.
Error on initialisation
epython-host: ee_write_esys(): EPIPHANY_DEV file open failure.
epython-host: e_reset_system(): Failed
Error on system reset
epython-host: e_open(): Platform was not initialized. Use e_init().
Error opening Epiphany
epython-host: e_alloc(): Platform was not initialized. Use e_init().
Error allocating memory
gartor
Postby polas » Tue Dec 15, 2015 8:22 am
Hi Gartor,
Am sorry to hear you are having issues. From looking at this it seems more an issue with/finding/connecting to the underlying Epiphany. What version of the OS image are you using, is it the latest one or an older one? Especially if it is an older image, try to run this as root (via sudo) - older versions of the API required you to be root in order to connect to the Epiphany, but this was fixed later on. The .sh script *should* handle this but has only been tested on my headless image - just edit the .sh script and put a hash (#) before lines 23,24,25, 26, 28 as it might not be picking up the correct OS version.
If this doesn't work then do other examples (such as those in the test directory on the image) all work OK? The wrapper script in epython.sh requires that the EPIPHANY_HOME environment variable is set so it is worth checking that this is correct (via the export command in bash.) If you look at the script it makes some assumptions about the location of your library directory and HDF file, it is worth checking that these are correct on your system, for instance does /opt/adapteva/esdk/bsps/current/parallella_E16G3_1GB.hdf for you?
Let me know how you get on,
Nick
polas
Postby ioiomi » Tue Jan 05, 2016 11:40 am
ioiomi
Return to Python
