Need help creating parallella.bit.bin
Postby shmueli » Mon Nov 02, 2015 9:12 am
Hi.
I'm trying to boot Ubuntu headless image with a custom FPGA configuration.
I've done the following steps:
1) Used Win32 Disk Imager to flash an SD-card with the latest Ubuntu 14.04 Parallella (Zynq7020) headless image.
2) Logged in the terminal with MobaXterm. - Everything works fine :)
3) Downloaded FSBL.elf and u-boot.elf from: https://github.com/parallella/parallella-flash.
4) Used Vivado 2014.3.1 to generate a bitstream from the parallella_7020_headless.xpr.zip project, which can be found here: https://github.com/parallella/parallell ... o/releases.
5) Exported everything to SDK and used the "create zynq boot image" tool to bundle FSBL.elf, elink2_top_wrapper.bit, and u-boot.elf into parallella.bit.bin (in this exact order).
6) Replaced the parallella.bit.bin file on my SD-card with the one I've just made. Did not change devicetree.dtb and uImage.
7) Tried to log in with MobaXterm. - No success :( Advanced IP Scanner doesn't even find the device.
What am I missing?
Please help.
shmueli
Re: Need help creating parallella.bit.bin
Postby kirill » Mon Nov 02, 2015 10:53 am
parallella.bit.bin is not the same as boot.bin that you are generating. It contains only FPGA bit stream in "raw" binary format. You generate it using bootgen tool from SDK with "-split bin" option, here is a sample script and sample .bif file
https://github.com/Kirill888/parallella ... bootbin.sh
https://github.com/Kirill888/parallella ... r/7010.bif
FSBL and u-boot can not be changed via sd-card, if you need custom version of those you have to flash into internal ROM, and better have JTAG ready in case things go wrong.
kirill
