How to build gcc toolchain with -fno-leading-underscore
Postby yabin » Sun May 19, 2013 11:19 pm
e-gcc uses -fleading-underscore as default when using current build process, which means it always mangles a C function name with a leading underscore (main -> _main).
How can i build e-gcc toolchain with --no-leading-underscore as default?
Thanks in advance!
yabin
Re: How to build gcc toolchain with -fno-leading-underscore
Postby simoncook » Wed May 22, 2013 11:15 am
Hi yabin,
Although this does not build you a toolchain that uses that flag, you can modify in gcc/gcc/config/epiphany/epiphany.h the definition of USER_LABEL_PREFIX to "" so the compiler adds an empty prefix to function names.
Useful SDK Links: - - -
simoncook
Postby yabin » Sun May 26, 2013 6:29 am
yabin
