Questions about the Matmul16 example
Postby Richardye » Sun Nov 15, 2015 9:55 pm
Richardye
Re: Questions about the Matmul16 example
Postby sebraa » Mon Nov 16, 2015 1:44 pm
You can easily synchronize all cores on the Epiphany chip. But since the bandwidth between the host and the Epiphany chips is limited, it makes more sense to synchronize only a single core with the host (and have that core synchronize with all other cores inside the Epiphany system, then).
Postby Richardye » Wed Nov 18, 2015 9:32 am
Hi Sebera,
Thank you very much! So you means that it is the same if we just use me.corenum == 1 or 2 or 3 ... with the me.corenum == 0 ? Since we only need one core to be synchronize with the host and that core doesn't need to be the core 0 ? Here is my understanding, if anything is wrong, hope you can tell me ! Thank you all the same!
Best Regrads,
Richard
Richardye
Postby sebraa » Thu Nov 19, 2015 2:56 pm
Postby cmcconnell » Thu Nov 19, 2015 6:10 pm
I guess it makes sense to pick one of the cores 0 - 3, to avoid the traffic having to pass through other cores on the way to its destination.
Colin.
cmcconnell
Postby sebraa » Fri Nov 20, 2015 12:53 am
As far as I understand it, the external memory is located next to core 15 (bottom right).
Postby cmcconnell » Fri Nov 20, 2015 3:11 am
Colin.
cmcconnell
Postby sebraa » Fri Nov 20, 2015 3:33 pm
Take with a grain of salt, what I write now. I haven't tested it.
Inside the Epiphany, bandwidth is generally sufficient (our problem is the memory size and as a consequence of too little buffering, latency; not data throughput). To my understanding, the NoC routers queue at most one transaction per direction. So, if your top-left core writes many packets to shared memory, then these transactions will queue up at each affected intersection and basically kill all traffic on that path. So it is probably beneficial to designate the bottom right core for off-chip (shared memory) transactions.
Postby aolofsson » Fri Nov 20, 2015 4:48 pm
All 4 cores on right side are equidistant from dram. They all go through one 4:1 mux before going out on elink to the fpga.
Postby sebraa » Mon Nov 23, 2015 2:14 pm
Ah, thanks for the clarification!
