e-objcopy source
e-objcopy source
Postby jar » Tue Dec 01, 2015 7:10 pm
The e-objcopy utility seems only to exist in binary form. The epiphany-libs repository doesn't have the source (https://github.com/adapteva/epiphany-li ... ls/archive). Has this source been lost? I only ask because it would be helpful to take a look at it in order to bypass the relatively slow SREC conversion process with the loader and use the ELF format directly.
Re: e-objcopy source
Postby sebraa » Tue Dec 01, 2015 11:31 pm
The objcopy tool is part of binutils, so the source code should be .
Postby aolofsson » Tue Dec 01, 2015 11:55 pm
Direct elf load has been supported since 2015.1
Should be no need for srecs anymore.
