cannot find -le-loader
Postby gadget » Thu Dec 10, 2015 10:35 pm
Hello
Was recently running on the headless version and running eprime from the parallella-examples with no problems. Decided to change over to the HDMI version and all works except for eprime. When I build it gives me the error -
/usr/bin/ld: cannot find -le-loader
collect2: error:ld returned 1 exit status
Any help would be greatly appreciated. Thanks
Cheers, Michael
gadget
Re: cannot find -le-loader
Postby sebraa » Fri Dec 11, 2015 4:48 pm
Your HDMI-enabled image uses an older version of the eSDK.
Remove "-le-loader" from the linker flags and do not #include <e-loader.h>, then it should work.
Postby gadget » Fri Dec 11, 2015 5:46 pm
Thank you, will give that a try. One question, the eprime program need to generate a .elf file. So just in case is there away to upgrade eSDK on the hdmi version? Thanks again.
gadget
Postby gadget » Fri Dec 11, 2015 9:14 pm
Ok, that was a no to both the suggestion and to upgrading esdk. Thanks again for the help.
gadget
