How to check power? Device looks dead
Postby danbru1211 » Sun Dec 13, 2015 11:05 am
I didnt use the board for over a year now and I need it again. I got a new 5V 4A PSU. This one is working fine (i measured and tested it).
I did setup the micro sd correctly. When I connect the power cord to the parallella board, no led or anything is going on!
Is there an easy way to debug this?
danbru1211
Re: How to check power?
Postby danbru1211 » Thu Dec 17, 2015 7:29 pm
no ideas?
danbru1211
Re: How to check power? Device looks dead
Postby aolofsson » Fri Dec 18, 2015 12:39 am
If no lights at all come on when you apply power, then the board might have died. Based on history, the most likely reasons why this would happen:
-using a supply of > 5V at some time (even for just a second).
-leaving the board unattended on without proper cooling for days/weeks
-something was shorted on board through metal
-ESD shocks (not handling the board with proper esd care)
Postby danbru1211 » Sun Dec 20, 2015 9:36 pm
Is there any part I could check / change?
I know how to solder and have the equipment.
danbru1211
