Hello_world ESYS mmap failure
Postby wilsonk » Thu May 23, 2013 10:22 pm
Just letting you know that some users running the hello_world example may run into this error with some server/secure distros of linux.
I am running Scientific Linux 6.2 here and the kernel has been compiled with the CONFIG_STRICT_DEVMEM option set to 'y'. This option will not allow me to write to a shared mmaped area (as root or user). I managed to get the example to run (with incorrect blank output from each eCore) by also making the calls to mmap in epiphany-hal.c use the MAP_ANON flag or'ed with the MAP_SHARED flag. Not really a solution...just a workaround to make sure things compiled ok and can sort of run.
I am not aware of a solution to this besides rebuilding the kernel without this protection (which I don't want to do). Perhaps using shm_map can get around this issue? Not sure as I haven't looked at this much.
If someone else can shed some light on this it would be great...maybe I am just doing something wrong and there is a simple solution or workaround.
Kelly
wilsonk
Re: Hello_world ESYS mmap failure
Postby 9600 » Fri May 24, 2013 8:17 am
Hi Kelly,
Thanks for alerting us to this problem!
Open + mmap on /dev/mem is clearly not ideal and an alternative method that would allow users to access the Epiphany accelerator without being root is on the to-do list, and it looks as though .
