Can you help me build hello_world.c for a parallella board
Postby Dr.BeauWebber » Fri May 31, 2013 2:44 pm
Dr.BeauWebber
Re: Can you help me build hello_world.c for a parallella boa
Postby ysapir » Fri May 31, 2013 3:23 pm
Postby Dr.BeauWebber » Fri May 31, 2013 3:46 pm
Thanks ysapir,
echo $PATH
/opt/adapteva/esdk/tools/e-gnu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games
echo $EPIPHANY_HOME
/opt/adapteva/esdk
ls -l /opt/adapteva
total 4
lrwxrwxrwx 1 root root 15 2013-01-14 19:20 esdk -> esdk.4.13.01.04
drwxr-xr-x 6 linaro linaro 4096 2013-05-31 12:53 esdk.4.13.01.04
Dr.BeauWebber
Postby ysapir » Fri May 31, 2013 3:48 pm
Postby Dr.BeauWebber » Fri May 31, 2013 4:01 pm
Thanks ysapir, will do, cheers, beau
Dr.BeauWebber
Postby Dr.BeauWebber » Fri May 31, 2013 9:13 pm
Dr.BeauWebber
Postby aolofsson » Sat Jun 01, 2013 1:41 am
You will need to add the following to your .bashrc for the new SDK to work.
export EPIPHANY_HDF=${EPIPHANY_HOME}/bsps/zed_E16G3_512mb/zed_E16G3_512mb.hdf
We will add this line to the INSTALL instructions on the parallella ftp site. Note that the actual HDF used depends on the board you are using.(the above line should be correct for your board).
Postby Dr.BeauWebber » Sat Jun 01, 2013 10:26 am
Thanks indeed,
Yes the hello-world.c script now builds and runs fine on all the processors.
In summary :
I got the hello-world scripts from esdk.4.13.04.24_linux_x86_64_armv7l.tgz
from esdk.4.13.04.24\examples\hello_world
The esdk being run on the hardware was upgraded to esdk.4.13.03.30_linux_armv7l.tgz
set run $EPIPHANY_HOME to point to the esdk (if it does not already)
run $EPIPHANY_HOME/setup.csh
Add to .bashrc (and run :) (for the board I am using)
cheers,
Beau
Dr.BeauWebber
