Aplc now running on Parallella hardware : Hello world
Moderator: Dr.BeauWebber
Postby Dr.BeauWebber » Sun Jun 02, 2013 11:46 pm
Reason: small tidy for future consistency
Dr.BeauWebber
Re: Aplc now running on Parallella hardware : Hello world
Postby ysapir » Mon Jun 03, 2013 3:14 pm
Happy to see you resolved the build/run environment issues. 8-)
Postby Dr.BeauWebber » Mon Jun 03, 2013 4:56 pm
Thanks ysapir,
I still have a query re having a split internal/external memory system - see my post in the SDK group.
I need to sort this before I do any timings.
I am currently trying to create a simple but more general output communication method.
cheers, Beau
Dr.BeauWebber
Postby Doug_Bohrer » Sat Jan 23, 2016 5:48 pm
I first learned how to program in APL as a high school student in 1968. I used APL interpreters professionally from 1978 until about 2006. The main advantage was that it coded up very fast. The main disadvantage was that it was very inefficient on single core Turing machines. I used it for applications that were complex, but did not run very often. Usually that meant accounting, corporate planning or investment managed account systems. All during that time, the APL community thought that when the hardware went massively parallel, APL would become the natural choice for programming because it was inherently parallel. That's how I stumbled on to your posts. Are people using your APL for development work? Did you connect the interpreter for prototyping code which could then be compiled after it was debugged? I am really curious about the usage of APL because it looks like most of the world is struggling to adapt languages designed for Turing machines to work in the parallel environment. I think that's a fool's errand. Doug Bohrer
Doug Bohrer
Chicago, IL
Doug_Bohrer
Postby Dr.BeauWebber » Tue Jun 14, 2016 9:18 pm
Fitting Apl, even compiled Apl, into a single core on one of these Array processors is a tight squeeze.
What we also need is a pipes to join the processors together.
I hope to do more work on these systems soon, but am busy elsewhere at the moment.
cheers,
Beau
Dr.BeauWebber
Postby Asterion » Sat Apr 11, 2020 4:53 am
Asterion
Return to APL
