Parallella Ubuntu ESDK 2016.3 released
Postby olajep » Mon Apr 11, 2016 1:14 pm
Re: Parallella Ubuntu ESDK 2016.3 released
Postby pgater » Mon Apr 11, 2016 7:10 pm
Hi Ola,
Many thanks! :D
Paul
pgater
Postby sebraa » Mon Apr 11, 2016 8:30 pm
Thank you!
Postby MiguelTasende » Tue Apr 12, 2016 12:21 pm
Great!
Will grab it today :P
MiguelTasende
Postby jar » Tue Apr 12, 2016 3:23 pm
Tables 6, 7, and associated text should be updated in the Epiphany architecture reference for the ABI changes.
Postby MiguelTasende » Thu Apr 14, 2016 5:24 pm
MiguelTasende
Postby MiguelTasende » Thu Apr 14, 2016 8:02 pm
Comment: Looks like it is necessary to remove "_" in assembly global function names... (when mixing asm and C)
After that it works...
I could see some differences transfer in times, but still testing...
Edit: Yep, it goes faster :) . By now just a small gain "out of the box", but I saw some real evidence that the new e-link is there.
MiguelTasende
Postby aolofsson » Thu Apr 14, 2016 9:35 pm
-ARM initiated transfers are are software bound, nothing to do with the elink
-As you can see the ERAM read speed increased by 2X (that's signifiacant!)
-If you run the matmul example, you can see a significant wall time speed up.
We'll look into the ARM-->ERAM read/write speed (has noting to do with elink, but agree that slow down is not good)
Postby olajep » Fri Apr 15, 2016 9:37 am
Postby MiguelTasende » Tue Apr 19, 2016 2:26 pm
MiguelTasende
