ebsp-hello project error [New 15.04 Image]
Postby prasadp4009 » Wed Apr 13, 2016 9:11 am
Hi Everyone,
I just downloaded the new 15.04 image released yesterday. I am trying to build the ebsp-hello project but got some error, can you guide me
Error:
parallella@parallella:~/Parallella/parallella-examples/ebsp-hello/epiphany-bsp$ make
CC src/host_bsp.c
CC src/host_bsp_memory.c
CC src/host_bsp_buffer.c
CC src/host_bsp_mp.c
CC src/host_bsp_utility.c
ar: creating lib/libhost-bsp.a
CC src/e_bsp.c
src/e_bsp.c: In function ‘bsp_begin’:
src/e_bsp.c:62:43: warning: passing argument 2 of ‘e_barrier_init’ from incompatible pointer type [-Wincompatible-pointer-types]
e_barrier_init(coredata.sync_barrier, coredata.sync_barrier_tgt);
In file included from /opt/adapteva/esdk.2016.3/tools/e-gnu.armv7l/epiphany-elf/include/e-lib.h:36:0,
from ./include/e_bsp_private.h:28,
from src/e_bsp.c:23:
/opt/adapteva/esdk.2016.3/tools/e-gnu.armv7l/epiphany-elf/include/e_mutex.h:46:6: note: expected ‘volatile e_barrier_t ** {aka volatile char **}’ but argument is of type ‘e_barrier_t ** {aka char **}’
void e_barrier_init(volatile e_barrier_t bar_array[], volatile e_barrier_t *tgt_bar_array[]);
src/e_bsp.c:133:46: warning: passing argument 2 of ‘e_barrier’ from incompatible pointer type [-Wincompatible-pointer-types]
e_barrier(coredata.sync_barrier, coredata.sync_barrier_tgt);
/opt/adapteva/esdk.2016.3/tools/e-gnu.armv7l/epiphany-elf/include/e_mutex.h:47:6: note: expected ‘volatile e_barrier_t ** {aka volatile char **}’ but argument is of type ‘e_barrier_t ** {aka char **}’
void e_barrier(volatile e_barrier_t *bar_array, volatile e_barrier_t *tgt_bar_array[]);
src/e_bsp.c: In function ‘bsp_sync’:
src/e_bsp.c:162:42: warning: passing argument 2 of ‘e_barrier’ from incompatible pointer type [-Wincompatible-pointer-types]
src/e_bsp.c:195:38: warning: passing argument 2 of ‘e_barrier’ from incompatible pointer type [-Wincompatible-pointer-types]
src/e_bsp.c: In function ‘ebsp_barrier’:
src/e_bsp.c:199:38: warning: passing argument 2 of ‘e_barrier’ from incompatible pointer type [-Wincompatible-pointer-types]
src/e_bsp.c: At top level:
src/e_bsp.c:214:33: error: interrupt handlers cannot have arguments
void __attribute__((interrupt)) _int_isr(int unusedargument) {
compilation terminated due to -Wfatal-errors.
Makefile:71: recipe for target 'bin/e/e_bsp.o' failed
make: *** [bin/e/e_bsp.o] Error 1
prasadp4009
Re: ebsp-hello project error [New 15.04 Image]
Postby sebraa » Wed Apr 13, 2016 2:13 pm
Postby jwbuurlage » Tue Apr 19, 2016 10:45 pm
I am one of the developers of Epiphany BSP. We have not yet updated our library to support the new SDK version (2016.03 but we are planning to release an update soon. I will also make sure this example gets updated.
Jan-Willem
jwbuurlage
Postby jwbuurlage » Sat Apr 30, 2016 2:25 pm
Hi, we just released a new version. The example should now also work with the new release, sorry for the inconvenience.
jwbuurlage
