Suggestions for COPRTHR-2
Moderator: dar
Postby CyberHiPriest » Mon May 02, 2016 3:14 pm
Server park:
Parallella Z7010 w/ E16G03 (microserver) with Linaro Ubuntu 15.04
PowerPC405 board with custom Linux 2.6.35
PowerPC e300c3 board with custom Linux 2.6.38
Marvell 88F6192 board with Arch Linux
MIPS64r3 board with custom debian Linux 2.2.27
CyberHiPriest
Re: Suggestions for COPRTHR-2
Postby jar » Tue May 03, 2016 1:29 am
OpenCL support is being deprecated in COPRTHR 2.0. It has been discussed at length on the forum why it is not a good programming model for the Epiphany architecture. I am not the developer but you csn always email him directly.
You might want to try out 2.0 since there are many good features. Many of the things you mentioned are already there. Others aren't so obvious. For example, you may want initialization code that is large but only called once to run out of shared DRAM. The tools for binary analysis are there and will enable you to control code placement better.
If you like having the OpenCL data types and functions, you can always pull in that header from 1.6 for a hybrid programming model. I do have a more complete version of it if I ever get around to releasing it. Many of the math functions could also be incorporated into the PAL library.
Postby dar » Tue May 03, 2016 3:39 am
Decision to deprecate OpenCL in COPRTHR-2.0 is not absolute. It is not a priority, will not be supported in the initial releases, and threaded MPI provides a much more efficient programming model. These suggestions are good and as JAR said many of these things have been addressed in COPRTHR-2.0.
dar
Return to OpenCL
